Anyone suggest a suitable Boost level after fitting a Manual Boost Controller on my 855 T-5? Without setting anything just taking the MBC out of it's box fitting it I now have 14-15 PSI boost on Eco mode, unfortunately I can only test at motorway speeds upto 70mph so the stock boost needle isn't going full swing as it's been suggested
Next weekend I've got some track time after a full brake refit [This thing is so heavy on brakes 3rd set of pads 2nd set of discs since March]
Boost level after fitting MBC 855 T-5
855 T-5 RHD Blue: MBC, Custom Map based on Rica, K&N Filter, 18T Turbocharger, White/Green injectors [depends on my mood], Blue Silicone vacuum hoses
- phils94850
- Year and Model: 2009 s60 turbo
charly.. do you know what your remap is set at ? you should be able to run 15 safely with a good remap.
1996 Platinum Edition
- Has thanked: 2656 times
- Been thanked: 1248 times
I'm consolidating MBC topics. Please use this MBC topic, thanks.
