ECC Flashing lights -Where is the temp sensor?
This topic is in the MVS Volvo Repair Database » iPod for my new S40 T5
dj5150
Year and Model: c70 2001
Post by dj5150 »
2001 C70 last week the blower quits on me and I get the flashing lights. It would blow for just a second then quit. I replaced the resistor pack now it doesnt even blow for that one second. where is the temp sensor located on the car so I can at least check it out before I replace the blower??
Advice?? Its getting COLD here in the northeast and I look ridiculous wearing a snuggie while I am driving.
jda2000
Year and Model: 04 V70 2.5T 01 V70T5
Post by jda2000 »
the cabin air temp is in the ECC module itself, just behind the open slits at the bottom right.
Need to remove the ECC to get to it.
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
Cabin temp sensor is in the row of dash switches behind what looks like a drill (right side of steering column)
You need to pull out the radio, maybe the climate control unit, reach behind and push it out
If it's that bad you probably need a new one.
Did you try blowing compressed air into it first.
It's a little fan that gets clogged with dust and dirt
If you go to Volvo their scanner will tell you which stored code you have, the sensor, the blower or resistor pack
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 93 times
Been thanked: 146 times
Post by BEJinFbk »
I think what Jim means is "a little Grill".
dj5150
Post by dj5150 »
thanks very much, I will try blowing it out, Can someone tell me how to operate a can of compressed air? ; )
dj5150
Post by dj5150 »
I can rule out the $116 resistor pack!
