2001 C70 last week the blower quits on me and I get the flashing lights. It would blow for just a second then quit. I replaced the resistor pack now it doesnt even blow for that one second. where is the temp sensor located on the car so I can at least check it out before I replace the blower??
Advice?? Its getting COLD here in the northeast and I look ridiculous wearing a snuggie while I am driving.
ECC Flashing lights -Where is the temp sensor?
iPod for my new S40 T5
JRL
- Year and Model: Several
- Been thanked: 16 times
Cabin temp sensor is in the row of dash switches behind what looks like a drill (right side of steering column)
You need to pull out the radio, maybe the climate control unit, reach behind and push it out
If it's that bad you probably need a new one.
Did you try blowing compressed air into it first.
It's a little fan that gets clogged with dust and dirt
If you go to Volvo their scanner will tell you which stored code you have, the sensor, the blower or resistor pack
- 191 Views
Last post by AlanHMultiV70s
- 2966 Views
Last post by 98S70T5
