Clock light
bionic bulldog
Year and Model: S80 2003
Post by bionic bulldog »
hi. hope someone can help me here.
all things on my dashoboard are illuminated ok, except for the clock. although if i get close enough i can see the clock is still showing and working, the "backlight" is not on. none of the electrical schematics i have mention anything of a bulb only for the lcd clock display. beginning to annoy me now as i drive a lot at night and can no longer see the time.
help please.
thanks
DrDootz
Year and Model: 1999 S80 2.9
Post by DrDootz »
There are 6 bulbs that light up different areas. There is one directly behind the clock display. The bulb assembly is around $6.50. On the S80, there are 2 screws that hold the black plastic shroud around the display. Then there are 4 T20 screws that hold the instrument module in. It pulls right out and the bulb assembly twists out. It took me 30 min for the entire job.
Good Luck
Here is a picture after the repair. The newer bulbs actual look brighter that the stock ones.
Repaired clock light
bionic bulldog
thanks. after your instructions found the bulbs and got it replaced. now i got my clock back
tuplip_73
Year and Model: s60 2002
Post by tuplip_73 »
I can not find the screws to take the black plastic shroud off. Will you so kindly tell me the location step by step and then where do I look for the other four screws. Thanks.
yuckuJackD
Year and Model: XC70; S80; S40
Post by yuckuJackD »
Good luck
Combined_Instrument_Panel.pdf
(77.54 KiB) Downloaded 543 times
A member of VolvoClub Bulgaria
Of All The Things I've Lost,
I Miss My Mind The Most.
VOLVO 440 1.7i 89y. B18E
VOLVO 460 1.8 mono 91y. B18U
VOLVO S40 1.8 115hp 16V 97y. B4184S
VOLVO S80 2.9 200hp '00y. B6294S
VOLVO XC70 D5 185hp '06y. D5244T4
tuplip_73
Post by tuplip_73 »
Thank you so much, I had to remove the plastic trim to get access to the screws. I let you know how the installation goes. Again thanks for procedure with pics.
tuplip_73
Post by tuplip_73 »
tuplip_73 wrote:Thank you so much, I had to remove the plastic trim to get access to the screws. I let you know how the installation goes. Again thanks for procedure with pics.
The job was successful, the clock works great, took abt 15 min.
