no heat/ foul smell
khs
no heat/ foul smell
I have a 98 Volvo S70 when I turn on the heat no hot air comes out and a white foul smelling mist comes out of the vents? Any idea what needs to be replaced and is it an easy fix?
White850Turbo
- Year and Model:
Is the level of coolant in the overflow tank fluctuating at all? Is there a damp spot under the passenger side carpet under the dash area?
-Sean
1995 850 Turbo (Extensively Modded)
1998 S70 T5 (Almost Stock)
khs
I did notice that the level of coolant was low in the overflow container, but there was not a wet spot under the carpet.
White850Turbo
- Year and Model:
Hhmmm, how is the engine coolant temperature once up to operating temperature? Should be somewhere close to the 3:00 position on the gauge cluster. You're A/C and Rec lights aren't blinking, are they? I suppose the smell is somewhat like a mildew sort of smell?
-Sean
Hate to butt in on this post but I have a curiosity question... my Rec and A/C lights were blinking at one point but have since stopped... what might that indicate?
Thanks!
Bryan
1994 850 Turbo Wagon - stock - no mods
Thanks!
Bryan
1994 850 Turbo Wagon - 218,000 Miles
White850Turbo
- Year and Model:
Depends, you'd have to pull your codes stored in the B1 socket of the diagnostic module under the hood up near the windshield washer resevoir and reference them to find their meaning.bryang wrote:Hate to butt in on this post but I have a curiosity question... my Rec and A/C lights were blinking at one point but have since stopped... what might that indicate?
Thanks!
Bryan
-Sean
- 399 Views
- 320 Views
Last post by Flyingdutchman
