Heated seats
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
Garry L
Heated seats
Post by Garry L »
Sorry, one more thing! ('91 740 again)
The car's front seats are heated, yet only the passenger seat gets warm, and it's only on the base, not the back. Is there any way to fix it so the driver's seat can be heated again? I checked the fuse panel and it's not shorted out, so I thought maybe it was old wiring since the car is 14 years old. The buttons to operate the heated feature still work, cuz the lights come on. Any ideas/information appreciated. Thanks!
LaRy
Year and Model:
Post by LaRy »
It is very common that the heat gets broken. You can take the upholstery off and you will find an electric resistance wire under there. That wire use to get broken by mechanical stress when you sit on it. In most cases the spot is easily found by a small burning mark. This is easy to repair by soldering and put on some new insulation. It could also be the thermostate placed under.
If you need more advices how to take upholstery off, please get back to this forum.
Garry L
Post by Garry L »
Thanks for replying LaRy, and yes, advice on how to take off the upholstery would be greatly appreciated! :D
LaRy
Year and Model:
Post by LaRy »
You have to take the whole seat out including the rails. Loosen all electrical connections under the seat. Loosen the plastic covers in floor level placed in front of the rails. Loosen the two bolts and the seat can be taken out by sliding
Guest
Post by Guest »
Thanks for the detailed instruction! It really helps, I appreciate it. :D
Garry L
Post by Garry L »
