S70 fuel economy or lack of it...
- Has thanked: 2866 times
- Been thanked: 1332 times
Chopper, this Stage 0 tuneup will have a bunch of info that will be helpful to you, assuming you haven't seen it already.
elchopperfreak
- Year and Model: S70 T5 1999
Prob 50 to 60 mph, Highway I mean, with tolls and idiots on the left lane talking on their phones..Not Interstate 75jblackburn wrote:I think I would cry if that was the best mileage I got on the highway. That's no better than a V8.
What kind of speeds did this run entail?
Hwy time was around 15 to 20 min each way at the most I would say. The rest is city, my wife did not reset the odometer so I really and kinda guessing..
zhenya
- Year and Model: 97 855 T5,98 V70 AWD
I'm not sure, exactly, although they are a Volvo-only shop, and tend to only use parts that last. they know which stuff is the junk. At about $60 for the entire job, I didn't think too hard about it.elchopperfreak wrote:Which ones did your mechanic use? oem?
Thanks for the info
elchopperfreak
Update.
Today just city driving, 15.6 mpg, quite a drop.
elchopperfreak
matthew1 wrote:Chopper, this Stage 0 tuneup will have a bunch of info that will be helpful to you, assuming you haven't seen it already.
Thanks Matthew, will check it out.
elchopperfreak
For stage 0
Plugs will be the bosch copperhead
What would be the best choice for cap and rotor? ( i seethe tutorial is using bosch)
Oil and filter, which is the best working oil for these cars, and filter
Air filter, K&N it is
Plug wires bougiecord/oem?
Anything else??
Anything else??
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
It's a 99? You dont have any of that - each plug has individual coil packs on each cylinder. Unless you are getting misfire codes then you don't need to worry about them. Your car also only uses a cartridge insert oil filter. Probably OEM Mahle/Mann filters are still the best.
'98 S70 T5
2016 Chevy Cruze Premier
elchopperfreak
JBlackburn
What do I dont need.? (guessing the rotor and cap)
Thanks
Thanks
jblackburn
Rotor, cap, wires - all that is gone from the 1999.
'98 S70 T5
elchopperfreak
14.1 mpg today, all city... Yuuckkkk..
- 18 Replies
- 5632 Views
Last post by FezMonki
- 1317 Views
Last post by misha
- 24 Replies
- 8116 Views
Last post by FlorenceTravis
- 3135 Views
- 2197 Views
Last post by Chock
