wet carpet on driver side?
tkende06010
- Year and Model: 850glt,1996
Hi all, moving on to the next issue with my 96 Volvo 850 N/A, The car has been in the garage for about 4 weeks now while I have done various repairs. The carpet in front and back on driver side mostly, is wet. I did not run the car for about 5 days, and it started to dry up so I figured it had gotten wet outside somehow, but after fixing pcv system and running the car to check it, I noticed the floor was wet again. When I rub my hand on it, it feels oily, and I suspect it may be the heater core leaking? I have not really noticed the coolant going down, but I have not driven the car at all for 2 months, so it may not have had a chance to go down noticeably? Anybody with input? i looked for a tutorial on this, but can't find anything for the 850. Thanks
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
Heater core for sure!
A lot of write-ups for the the S/V70 series, but I'm pretty sure the 850 is nearly identical.
http://volvospeed.com/vs_forum/topic/97 ... e-install/
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
tkende06010
thanks for the input, if I stuff my head under the dash, I can see a bit of a white plastic box, which I think the core is in.
Fish stick88
- Year and Model: 1994 - 850 Sedan
thats right. I had the same problem too.. make sure to check all of your drains too, they could be clogged
Speed has never killed anyone, suddenly becoming stationary... That's what gets you.
'94 850 Sedan - 160k miles
brownslanejag
- Year and Model: 960 1995
How about for the 1995 960? My core is leaking. And the shop wants 1500.00 bucks to fix it. They say that the whole dash has to come out? And where is it on the 960?
Fish stick88
the whole dash does have to come out, unless you want to cut apart your car to get to it. its a tricky fix, and it depends on where its leaking 850's ahve the easiest core to replace, it should be similiar on your 960. Try looking up "960 Dash Removal" in the repair database, should show something.
FCPEURO
- Year and Model: 2006 XC90 V8
- Been thanked: 19 times
Common symptom of heater core failure. I have the OEM Nissens unit for it available below, is a bit tedious to replace on your model (as previously stated, dash has to come out for access). But not as bad when it comes down to the work itself, you should also check your hoses and the small o-rings leading to the coupler at the firewall. Something that is often overlooked and could cause future leaks.
http://www.fcpeuro.com/products/volvo-h ... 70-s70-v70
I know replacing the core kinda sucks, but I hope this helps!
FlyingVolvo
Don't forget to replace the o-rings too!
2023 V60 T8 PE
2023 V60 T8 PE
tkende06010
Thanks guys, I am going to take it out in the next day or two, I will let everyone know how it goes, and I will get some pictures too
- 627 Views
- 5855 Views
Last post by gobies
- 1212 Views
Last post by vtl
- 3442 Views
Last post by SuperHerman
- 525 Views
Last post by MDK
