Power Window
1996 - 2004 S40
1996 - 2004 V40
pwhisler
Year and Model: S40 1.9T 2002
Power Window
Post by pwhisler »
I have a problem, here is a video, does anyone know what the problem is and how to fix it? its the driver's side window
it goes down without a problem, but on the way up, it gets stuck and makes that noise at 1/3, 2/3 and all the way at the top. I can pull it with my hand to get it through that stuck point.
as a side note, how do you embed videos on here?!
thanks!
2002 Volvo S40 1.9T
69,xxx miles
pwhisler
Post by pwhisler »
anyone have a thought?
pwhisler
Post by pwhisler »
could it be the power window motor? but i'm not sure why it goes down smoothly, and up smoothly except for those 3 spots.
or could it be the control module?
pwhisler
Post by pwhisler »
do you think it is off track? i didn't see any posts on here about fixing an off track window on an s40, anyone have diagrams? do i have to buy something?
pwhisler
Post by pwhisler »
i sent an email to ipd and got this response:
Hi,
Most likely you are going to need to replace the window regulator assembly. The motor and gear assemblies are all pressed together into a non serviceable part. It has to be replaced as a complete assembly. We don't stock it, but we can order one for you for $268,
Volvo part # 30623448. You might be able to get a used one from a wrecking yard for around $100.
Let us know if you'd like to get one on order.
Thanks and good luck,
Scott Hart
Volvo Division Leader
ipd
does this sound right to anyone? anyone know where i can get a cheaper one/used one?
pwhisler
Post by pwhisler »
Hi Paul,
Most likely the coil wrapped steel cable is worn in the area that is slipping. Possibly you might be able to get some more life out of it by lubing the cable and felt window tracks, but it sounds like its worn pretty bad base on the video you made. I have attached a pic of the regulator assy and a sunroof steel cable just so you can get a sense of what you’re dealing with
Not sure how difficult the job is, but would estimate it to take 1-2 hours.
Good Luck with it.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2652 times
Been thanked: 1242 times
Post by matthew1 »
Hi pwhisler, sorry nobody's gotten back to you. I'll start with what I do know, and work toward what I don't. :-)
How to embed YouTube videos at on MVS Volvo Forums.
BUT, recently YouTube began making their "Share" URLs look like this
[YouTube][/YouTube]
Notice the domain is youtu.be, not youtube.com. That throws the forums' video tag off, so when you apply the YouTube tag, it doesn't work.
The solution -- until I fix the code on MVS -- is to copy from your browser's URL bar, then wrap in the MVS YouTube tag.
Code: Select all
[YouTube]http://www.youtube.com/watch?v=7iq9eLSs4gg[/YouTube]
... which yields
Ok, on to what I don't know about. Like a good seat-of-the-pants shadetree mechanic, I'd take the door panel off and see what you find. half the time you get lucky and it's obvious, like a broken $4 guide clip. Here's an '05 S40 door panel removal guide, but that or '04 was a "split year" so it may not match exactly your door.
Reason: Removed erroneous sentence about removing question mark in the YouTube URLs.
Also -> Amazon link
pwhisler
Post by pwhisler »
great, thanks for the reply and help. i did take the door panel off, and played with the switch, but didn't see anything unusual...
i attached the two images the ipd guy sent to me, does that sound like that could be the solution?
jchrisf
Year and Model: S40 2001
Post by jchrisf »
Sounds like you are going to have to replace the window regulator unit. I had to do this on my 01 a couple of months ago and it is easy.. expensive but easy. I actually found the part for around $140 for my car. I thought it might have been the motor so I took the regulator out of another door and swapped motors. That didn't fix it so the only other option was the whole assembly.
pwhisler
Post by pwhisler »
where did you find it for $140?
ipd - $268
oemvolvoparts - $206
volvowholesaleparts - $212
non of which includes shipping...
i couldn't find one on ebay
