I have a problem, here is a video, does anyone know what the problem is and how to fix it? its the driver's side window
it goes down without a problem, but on the way up, it gets stuck and makes that noise at 1/3, 2/3 and all the way at the top. I can pull it with my hand to get it through that stuck point.
as a side note, how do you embed videos on here?!
thanks!
2002 Volvo S40 1.9T
69,xxx miles
Power Window
i sent an email to ipd and got this response:
does this sound right to anyone? anyone know where i can get a cheaper one/used one?
Hi,
Most likely you are going to need to replace the window regulator assembly. The motor and gear assemblies are all pressed together into a non serviceable part. It has to be replaced as a complete assembly. We don't stock it, but we can order one for you for $268,
Volvo part # 30623448. You might be able to get a used one from a wrecking yard for around $100.
Let us know if you'd like to get one on order.
Thanks and good luck,
Scott Hart
Volvo Division Leader
ipd
Hi Paul,
Most likely the coil wrapped steel cable is worn in the area that is slipping. Possibly you might be able to get some more life out of it by lubing the cable and felt window tracks, but it sounds like its worn pretty bad base on the video you made. I have attached a pic of the regulator assy and a sunroof steel cable just so you can get a sense of what you’re dealing with
Not sure how difficult the job is, but would estimate it to take 1-2 hours.
Good Luck with it.
- Has thanked: 2654 times
- Been thanked: 1247 times
Hi pwhisler, sorry nobody's gotten back to you. I'll start with what I do know, and work toward what I don't.
How to embed YouTube videos at on MVS Volvo Forums.
BUT, recently YouTube began making their "Share" URLs look like this
[YouTube][/YouTube]
Notice the domain is youtu.be, not youtube.com. That throws the forums' video tag off, so when you apply the YouTube tag, it doesn't work.
The solution -- until I fix the code on MVS -- is to copy from your browser's URL bar, then wrap in the MVS YouTube tag.
... which yields
Ok, on to what I don't know about. Like a good seat-of-the-pants shadetree mechanic, I'd take the door panel off and see what you find. half the time you get lucky and it's obvious, like a broken $4 guide clip. Here's an '05 S40 door panel removal guide, but that or '04 was a "split year" so it may not match exactly your door.
[YouTube][/YouTube]
Code: Select all
[YouTube]http://www.youtube.com/watch?v=7iq9eLSs4gg[/YouTube]Ok, on to what I don't know about. Like a good seat-of-the-pants shadetree mechanic, I'd take the door panel off and see what you find. half the time you get lucky and it's obvious, like a broken $4 guide clip. Here's an '05 S40 door panel removal guide, but that or '04 was a "split year" so it may not match exactly your door.
Reason: Removed erroneous sentence about removing question mark in the YouTube URLs.
great, thanks for the reply and help. i did take the door panel off, and played with the switch, but didn't see anything unusual...
i attached the two images the ipd guy sent to me, does that sound like that could be the solution?
- image003.png (19.83 KiB) Viewed 3064 times
- image004.png (78.58 KiB) Viewed 3064 times
Sounds like you are going to have to replace the window regulator unit. I had to do this on my 01 a couple of months ago and it is easy.. expensive but easy. I actually found the part for around $140 for my car. I thought it might have been the motor so I took the regulator out of another door and swapped motors. That didn't fix it so the only other option was the whole assembly.
