93 850glt
robt
Year and Model: 850glt 1993
Post by robt »
i have a 93 850glt, car idles fine but as soon as i put my foot down it stalls and cant start it for about 15min,fuel pump sounds ok
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Does the fuel pump works all the time?Do you actually hear it buzzing before the car dies?
You said that idle is fine.Does your rpm fluctuate up & down or it is steady?
Check engine light on?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
In Tasmania it would likely be a "lambda light" but that is where I would start so that we can be of more help to you.
Pull codes from both ports A-2 and A-6 and post back the results.
If you have not read the codes before on your car here is how it is done:
http://volvospeed.com/CheckEngine.php
robt
Post by robt »
misha wrote:Does the fuel pump works all the time?Do you actually hear it buzzing before the car dies?
no buzzing noises at all, rpm is fine,check engine light is off
robt
Post by robt »
Ozark Lee wrote:In Tasmania it would likely be a "lambda light" but that is where I would start so that we can be of more help to you.
code is saying no fault found. what is a lambda light? car come from south australia 6 months ago
misha
Post by misha »
Lambda light(european cars)=check engine light(us spec.cars).Since the car is from Australia,you maybe have us spec.check engine light instead of Lambda light(european check engine light).
It's the orange light with little green triangle in which is the Greek Lambda letter.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
misha
Post by misha »
robt wrote:...no buzzing noises at all, rpm is fine,check engine light is off
Do you actually hear that fuel pump is running?Do you hear it when you turn the key in ignition II for a second or two,before you start the car(you should hear it and that is called priming).When you prime it(key in ignition II),the fuel pump will run a second or two and than it will stop,then when you start the car it will run all the time.
My question is...do you actually hear that fuel pump is running before the car dies?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
robt
Post by robt »
My question is...do you actually hear that fuel pump is running before the car dies?[/quote
i can not hear pump when sitting in drivers seat with engine running
robt
Post by robt »
misha wrote:Lambda light(european cars)=check engine light(us spec.cars).Since the car is from Australia,you maybe have us spec.check engine light instead of Lambda light(european check engine light).
misha
Post by misha »
We MUST know if fuel pump is running before the car dies.
My advice is to ask somebody to listen for it's "noise" in the trunk or beside right rear wheel.
When we are sure that fuel pumps is ok,then we can go further.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
