Thanks taylor
P0442 code
taylor98v70xcharris
- Year and Model: V70 XC, 1998
P0442 code
Hello, first time poster long time reader, very helpful site. Anyway im the owner of a 98 v70xc and for the past three months iv been getting the p0442 error code. I know its a small evap leak but i was just wondering what are some things i could start checking? Iv replaced most of the vacume line (ran out of line
) and the "J" hose on the charcoal canister is fine. What else could it be?
Thanks taylor
Thanks taylor
- regent
- Year and Model: 2015 XC60 T5
- Has thanked: 2 times
- Been thanked: 12 times
Have you looked at your filler cap - a poorly sealing cap will set an evap code. (Sorry if this sounds like an unnecessary note)
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired
1987 340 DL - retired
2015 BMW 335i
JRL
- Year and Model: Several
- Been thanked: 16 times
Purge valve OK?
The fastest and most thorough way is to have the car smoked for vacuum leaks
Dell+
- Year and Model: 2001 V70 T5 5-speed
I've been having the P0442 code for quite a while. I got a new OEM gas cap ($26
) and reset the check engine light. It came back in two days. I am getting it smoke tested next. Research has shown it could be: gas cap, J-hose cracked at canister (on top of fuel tank), purge valve, small leak in any vac hoses, mini hole in fuel filler neck, even a MAFS. so i am getting it smoked and will report my findings next week!
taylor98v70xcharris
All great advice, thanks all. Yeah changed the gas cap and most of the vac lines and checked the "J" hose they all seem to be fine. I hope its not a hole in my filler neck, that doesnt look fun to change. What would a smoke test coust me? just an hour of labor maybe?
- Has thanked: 2654 times
- Been thanked: 1247 times
I've always been wary of this because of the heat/spark going on around the engine while spraying it. I'm no chemist, so perhaps it's unfounded. Anyone know for sure? Is propane better?
s70glt novice[Will]
- Year and Model: s70 glt 98
Hmmmmm.....I have a fog machine we used ONE halloween...I might want to try it. Any downside to sucking unknown chemical vapors into your vacuum lines?
'98 s70 GLT-127k
ARD Green, obx, 16t, other go-fast parts
- MoVolvos
- Has thanked: 310 times
- Been thanked: 524 times
Hello,
I found this very helpful!!!!
How To Find A Vacuum Leak
- 1036 Views
Last post by neworleans
- 927 Views
Last post by joe_pinehill
