850 washer pump replacement
deefer
Year and Model: 850 2.5 20v 1995
Post by deefer »
Hi,
I bought a replacement windscreen washer pump for my 850, and cannot get it to fit properly.
It is identical to the one removed.
But there seems to be no way to create a seal between the reservoir and the pump to stop water leaking out.
Is there a connector between reservoir and pump that I have lost? Or am I just being incredibly daft?
Thanks
ed7
Year and Model: V70XC 2005, 2001
Has thanked: 2 times
Post by ed7 »
Perhaps you're missing an o-ring or gasket to make the seal.
Ed
deefer
Post by deefer »
Thats all I can think of, Does anyone know what part is missing so I can order a new one?
byeboy
Year and Model: 850R, 1997
Post by byeboy »
I'm looking at the exploded parts drawing for that, and it does not show an O ring, just the pump into the tank, with a sensor going into a hole right next to it. Check the parts places (FCP Groton, etc. to look at their pictures, and see if it lists any O ring...also, enter 'Volvo 850 Washer Pump" into ebay, and see if any of those come with seals of any type.
ed7
Post by ed7 »
The breakdown is a bit sketchy:http://www.volvopartswebstore.com/showA ... her%20pump
Find the leak and take the parts with you to the hardware store to find a seal that may work.
Ed
deefer
Post by deefer »
It is literally the hole in the resevoir that the washer oump fits into, there has to be a grommet or something there.
Not sure if I could buy anything of the shelf that wouldn't leak as it has to fit the resevoir exactly and have a hole in the middle for the washer pump to fit into.
