940 searching idle in cold weather
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
Amys 940
Year and Model: 940, 1994
Post by Amys 940 »
Hi everyone. New to the forum and definitely enjoying the wealth of info! I have a 94' 940 non-turbo that's been great to our family and now has 208k on it. In the cold weather of winter, when I start the car, the idle goes up and down rhythmically. If I put it in gear too quickly, it can actually stall. This condition only seems to last about a minute. Wonder what it may be? Does this engine have one of those PCV traps that gets clogged? Idle air valve problem? Wondering where that valve is on this car? Doesn't seem to be built into the throttle body. Is it remote and run in with vac lines? Any help would be appreciated.
regent
Year and Model: 2015 XC60 T5
Has thanked: 2 times
Been thanked: 12 times
Post by regent »
Wlcome aboard, Amys 940
Start with cleaning your MAF sensor and ICV (check out the attachment for location of that hidden Idle CTRL) :D
940 Eng Components.pdf
Component Location 940
(77.66 KiB) Downloaded 191 times
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired :(
1987 340 DL - retired :(
Amys 940
Post by Amys 940 »
Thanks for the info! I really ought to take my idle air control out and clean it. I notice that I don't really have what looks to be the normal MAF sensor though. Mine is very small and looks to be a standard intake air temp sensor. Kind of weird. Anyone know anything about this? Please let me know. Thanks again. What a great forum!!
regent
Post by regent »
There should be a MAF meter to provide the air mass and air temp signals to the fuel CTRL system; it is usually located on or after the air box. There is also a Manifold Pressure Sensor on the intake.
2015 BMW 335i
Amys 940
Post by Amys 940 »
Yea, my car is kind of different from all the pics I see. The only thing in the entire air boot is a small two wire sensor. Nothing like the MAFs I've seen on other cars?? Trying to attach a pic. Took the IAC off and cleaned it out. We'll see tomorrow if that fixed the cold idle searching.
regent
Post by regent »
Take that back. It is a temp sensor.
2015 BMW 335i
regent
Post by regent »
On the 940 wiring diagrams, the fuel injection system types are shown on pages 28 through 33.
First, determine which fuel control system your car has, and then see if you can locate the MAF sensor (device 7/17 with a 6-pin connector on the prints); its physical location will depend on the type your fuel injection system. Also, the MAP sensor (Manifold Pressure) is device 7/50.
URL: https://www.matthewsvolvosite.com/downlo ... iagram.pdf
Hope this helps :)
2015 BMW 335i
Amys 940
Post by Amys 940 »
Any idea, then, how my car manages it's basic fuel control? I don't see a MAP sensor either. I'm sure the TPS has something to do with it. Older GM cars relied more heavily on O2 sensors for primary fuel control, but all other cars I know use them as a trimming device only. Wonder why my car seems to be a little different than other 94' 940s?
Amys 940
Post by Amys 940 »
Wow! Think I was writing as you were. Thanks for the great diagrams. I'll check them out now.
Amys 940
Post by Amys 940 »
Ok, it's definitely a Regina Fuel injection set-up but none of the 3 ignition systems seem to match mine. The closest is the Rex. The trouble is that I have a standard, plain-Jane distributor cap just under, and in front of the intake. Neither of the 3 systems show this type of distributor. However, the rest of the components, or lack thereof, seem to match the Rex. Do you happen to have the description and operation of the Rex/Regina systems? Thanks!
