No gears no codes
josefdavid
Year and Model: s70 T-5 98'
Post by josefdavid »
Hi fellow brickers,
I have a 98 s70 T5 I love it. just the other day. It decided to lose all its gears. I have no check engine light no flashing arrow and no gears. I shift into reverse it idles higher than in park when I shift into neutral I will idols lower than any other gear. Can some one please help?
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
Without the flashing up arrow all that I can come up with is that the torque converter blew up. Have you drained some fluid to look for metal shards? When the torque converter goes it tends to completely contaminate the fluid with fine metal that also contaminates the rest of the transmission.
josefdavid
I drained fluid and lo an behold sparkly lil flakes of disaster. So is there a fix?
Post by Ozark Lee »
josefdavid wrote:I drained fluid and lo an behold sparkly lil flakes of disaster. So is there a fix?
Yes there is a fix but it isn't fun. Start shopping for a used transmission.
They should come with the torque converter.
Toms usually has a bunch of them on eBay and Erie-Vo-vo should have them as well if you can't find anything locally. I think both of them give a 6 month warranty. Working with Erie Vo-vo is easier on the phone than by email.
josefdavid
Thank you so much this is a great help now I just have to figure out what to do.
josefdavid
Sorry one more question. What transmission will play nice with my 98 s70 t-5? Like what models can I take one out of....
Has thanked: 312 times
Been thanked: 818 times
Easiest will be from a 94 through 98, 850 or S/V/C70, turbo or non-turbo: automatic transmissions are all the same. Presumably the 98 AWD transmissions are different but I don't know.
trophytaker308
Year and Model: 1995 850t turbo
Post by trophytaker308 »
just get a torque converter and change the filter and fluid...just pull the old one out and install the new one.put it in and turn it till it pops all the way in and then make sure to turn again and try to pop it in again to make sure it is in..easy fix,just a little hard job pulling the tranny out.but you can have it out and in in about 3hrs give or take..goodluck man.cause your clutches should still be fine..dont try to drive it at all if it is a blown tq.
1995 850t turbo,siver with black leahter interior (perfect),, 118000 miles .second owner.9 out of a 10...!
JordanW
Year and Model: 96 850R
Post by JordanW »
What color was the fluid and how much drained out? Any chunks of metal on the drain plug magnet?
erikv11 wrote:Easiest will be from a 94 through 98, 850 or S/V/C70, turbo or non-turbo: automatic transmissions are all the same. Presumably the 98 AWD transmissions are different but I don't know.
Mostly true - the final drive ratio is different between turbo's and NA. 2.74:1(NA) 2.54:1(T). They can be interchanged, you'll likely see a difference in your MPG's and RPM's at highway speeds. There are plenty of these transmissions out there, get one from a turbo if you can. car-part.com is a good place to start.
trophytaker308 wrote:just get a torque converter and change the filter and fluid...just pull the old one out and install the new one.put it in and turn it till it pops all the way in and then make sure to turn again and try to pop it in again to make sure it is in..easy fix,just a little hard job pulling the tranny out.but you can have it out and in in about 3hrs give or take..goodluck man.cause your clutches should still be fine..dont try to drive it at all if it is a blown tq.
Not so much. You are NOT replacing the filter screen on this transmission without removing the front pump and housing. There is a filter, but it's not servicable without taking the transmission apart. The 3hr time quote is VERY optimistic.
96 850R = ARD Green m4.4, rip, Kilen's, C70vert subframe, S60R exhaust manifold, NA TB with 960 plate, SNAAB J pipe, MSD coil.
josefdavid
The fluid had been drained and filled about 3000 miles ago so it was more redish pink than brown. On the magnet there was build up of gunk and in the fluid there was also glittering flakes. Is it common for a trans in my situation to throw no codes at all not even a torque converter code. I'm puzzled for the fact it'll get gears for a couple of minutes then as your driving disengages. And my idle is all screwy higher in drive once disengaged then once you put it in park the idle goes down as if it's in gear.....
