reverse flow
How to go faster, stop quicker, and turn harder. Chips, exhaust, larger turbos, bigger/slotted/drilled rotors, high performance brake pads, manual boost controllers, performance shocks/struts/springs, airbox mods and more! Also discussion on HID and Xenon lights, aftermarket foglights and other exterior lighting.
new850
Year and Model: 850 t5 97
reverse flow
Post by new850 »
is it a good idea to reverse the flow comeing out ouf the turbo going into the inner cooler
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
You need to find data as to temp and horse power figure's from real world experimentation or Dyno testing to get the answer. Everything else is an opinion or feeling but it looks great under the hood and when your happy :D it feels faster :lol: !
RobTarD
Year and Model: V70R, 1999
Post by RobTarD »
If you're talking about the reverse intercooler piping, then no, it doesn't make a whole lot of difference.
new850
Post by new850 »
ipd has the reverse innercooler pipeing for $350 and was wondering if that was a way to go
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2656 times
Been thanked: 1248 times
Post by matthew1 »
To reiterate what Rob said, there are usually several bottlenecks to address before this. Some at lower cost, higher benefit.
Also -> Amazon link
RobTarD
Post by RobTarD »
new850 wrote:ipd has the reverse innercooler pipeing for $350 and was wondering if that was a way to go
What do you want exactly?
MoVolvos
Post by MoVolvos »
new850 wrote:is it a good idea to reverse the flow comeing out ouf the turbo going into the inner cooler
RobTarD wrote:If you're talking about the reverse intercooler piping, then no, it doesn't make a whole lot of difference.
matthew1 wrote:To reiterate what Rob said, there are usually several bottlenecks to address before this. Some at lower cost, higher benefit.
As RobTarD Stated what do you want exactly? If you are after a nicer looking engine bay then you can spend as much as you like otherwise there are no performance gains to speak of with the IPD Kit unless there is data out there to show it.
