reverse flow
reverse flow
is it a good idea to reverse the flow comeing out ouf the turbo going into the inner cooler
- MoVolvos
- Has thanked: 310 times
- Been thanked: 524 times
You need to find data as to temp and horse power figure's from real world experimentation or Dyno testing to get the answer. Everything else is an opinion or feeling but it looks great under the hood and when your happy
it feels faster
- Has thanked: 2656 times
- Been thanked: 1248 times
To reiterate what Rob said, there are usually several bottlenecks to address before this. Some at lower cost, higher benefit.
- MoVolvos
new850 wrote:is it a good idea to reverse the flow comeing out ouf the turbo going into the inner cooler
RobTarD wrote:If you're talking about the reverse intercooler piping, then no, it doesn't make a whole lot of difference.
matthew1 wrote:To reiterate what Rob said, there are usually several bottlenecks to address before this. Some at lower cost, higher benefit.
As RobTarD Stated what do you want exactly? If you are after a nicer looking engine bay then you can spend as much as you like otherwise there are no performance gains to speak of with the IPD Kit unless there is data out there to show it.RobTarD wrote:What do you want exactly?new850 wrote:ipd has the reverse innercooler pipeing for $350 and was wondering if that was a way to go
