timing issue, camshaft pully removed
tightlines1
- Year and Model: 94,850
How do I correctly align the cam pulleys onto the cams. After they have been removed without being marked.
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 78 times
There is a special tool that secures the opposite ends of the cams in the proper location. Then the sprockets are installed with the indexing marks lined up. I'm not sure, but there may be variations of the tool depending on which engine you have.
http://images.search.yahoo.com/images/v ... exvM3RJWdd
or
http://www.ebay.com/itm/Camshaft-Cylind ... 500wt_1351
or
- Year and Model: Lots
- Been thanked: 128 times
You can line up the exhaust and intake cams with the following photos. You will have one of the sprockets with a bolt at the top and the other with two bolts at the top.
I have aligned 5 cylinder heads with this method and while trickier when tightening the sprocket bolts (you'll need 2 10mm spanners to hold them still while tightening the 3rd with another)
I've always achieved good results and though while I'd rather have the alignment tools I've been spending big on other things like engine hoists, stands, scanner tools and general maintenance.
- Intake.JPG (35.15 KiB) Viewed 1048 times
- exhaust.JPG (34.68 KiB) Viewed 1048 times
jimmy57
- Been thanked: 320 times
You have to take the black plug off the back end of head and the camshaft sensor and its reluctor piece of the back of the other cam to see those back ends of cams.
The alignment of cams is to coincide with the crank marking being aligned with oil pump pointer line.
'chrism wrote:I was looking for those photos and couldn't find them anywhere.
They're from the Tracy's True Soaps Head Gasket tutorial
- 613 Views
Last post by precopster
- 11 Replies
- 37319 Views
Last post by Volvoman809
