can a s80 timing be set with out the cam lock tool
i replace a head gasket on my s80 but cant seem to get the timing marks to line up
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 78 times
At any point in the process, did you remove either one of the cam sprockets from its cam shaft? If not, you should be able to re-align the marks on each cam and the crankshaft.
- Year and Model: Lots
- Been thanked: 128 times
If you use the diagrams attached you should be OK.
There should be a mark on the cam sprockets which line up at 12 o clock.
Make sure the crank mark is set.
- exhaust cam.JPG (34.55 KiB) Viewed 2303 times
- intake cam.JPG (35 KiB) Viewed 2303 times
i did a head gasket replacement,both cam sproket was remove ,,i have been doing a lot of reading on this but its still beating me i think i kinda need some step by step instruction i tried making a cam lock tool but i am not sure where the the cams supose to be aling,i am determine to do this project on my own ,with all the help i can get from this site which seem to be the best volvo site
Some Matthews Volvo site links with tech write-ups about the S80 car (should keep you busy!!)
https://www.matthewsvolvosite.com/forums ... 11&t=45415 Stage 0 PCV fitout
https://www.matthewsvolvosite.com/forums ... =5&t=39908 Performance enhancements
https://www.matthewsvolvosite.com/forums ... 11&t=35482 Head rebuild S80T6
https://www.matthewsvolvosite.com/forums ... 11&t=34642 Setting VVT on cams
https://www.matthewsvolvosite.com/forums ... =1&t=32503 Trans fluid intervals
https://www.matthewsvolvosite.com/forums ... 11&t=25268 Timing belt replacement
https://www.matthewsvolvosite.com/forums ... 10&t=20094 Cabin Air filter replacement
https://www.matthewsvolvosite.com/forums ... 11&t=18016 Trans stuck in S mode
https://www.matthewsvolvosite.com/forums ... 11&t=18314 Timing belt thread
https://www.matthewsvolvosite.com/forums ... 12&t=17820 ETM news
Etm cleaning 2000 volvo s80 t6 ETM cleaning
https://www.matthewsvolvosite.com/forums ... 0892#50892 S80 Handbrake adjustment
