can a s80 timing be set with out the cam lock tool
Everything on the Volvo S80. Sometimes called an "executive car", the S80 was Volvo's top-of-the-line passenger car. P2 platform.
rusty1
Year and Model: 1999 s80
Post by rusty1 »
i replace a head gasket on my s80 but cant seem to get the timing marks to line up
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 78 times
Post by chrism »
At any point in the process, did you remove either one of the cam sprockets from its cam shaft? If not, you should be able to re-align the marks on each cam and the crankshaft.
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
If you use the diagrams attached you should be OK.
There should be a mark on the cam sprockets which line up at 12 o clock.
Make sure the crank mark is set.
exhaust cam.JPG (34.55 KiB) Viewed 2301 times
intake cam.JPG (35 KiB) Viewed 2301 times
jimmy57
Been thanked: 320 times
Post by jimmy57 »
T6 or 2.9?
rusty1
Post by rusty1 »
i did a head gasket replacement,both cam sproket was remove ,,i have been doing a lot of reading on this but its still beating me i think i kinda need some step by step instruction i tried making a cam lock tool but i am not sure where the the cams supose to be aling,i am determine to do this project on my own ,with all the help i can get from this site which seem to be the best volvo site
rusty1
Post by rusty1 »
its a 2.9
precopster
rusty1
Post by rusty1 »
i have al the marks lined tried starting engine turn over but still no start ,i am still at a stand still...lol
