98 v70 cam seal r&r now no start
Been thanked: 470 times
Re: 98 v70 cam seal r&r now no start
Post by cn90 »
redhorse2000 wrote:...Cleaned pic-up in sensor...
Since you already checked the rotor side and the sensor side, I have no idea why it does not start.
Double-check all vacuum lines, electrical connections.
A theory: you might have damaged the sensor while cleaning it.
Was the MAF plugged in.
Best is to take a few pics of your current condition, maybe some sharp eyes here can diagnose it for you. Without a few pics, hard to tell.
redhorse2000
Year and Model: v70,1998
Post by redhorse2000 »
Installed code from a friend of mine. Code reads p1617. Went to chart, p1617& p1618 shows same but when topic page is opened specifies for p1618 as trans scensor. This does not make sense as to not being able to start after seal replacement . I have checked all wire connections as advised an pins are clean have factory lube on them. Gee thought i was on go with this code reader , but stumped again. Any logical answer would be appreciated
Post by cn90 »
Did you check the ignition wire, the single wire that runs from the ignition coil to the distributor cap?
Very easy to overlook this baby.
Also, take a few photos of your current situation an post them here.
redhorse2000
p1617 is the code the scanner gives
Has thanked: 292 times
Been thanked: 765 times
that's a stumper. did you see this old post?
https://www.matthewsvolvosite.com/forums ... =1&t=36853
worth a try
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
