855T5R Bogs down when the throttle is pushed
gmtgmt
Year and Model: Volvo 850 T5R
Post by gmtgmt »
Im working on a costemers car. 1995 T5R has BSR ecu upgrade, complete 3 inch exhurst, bigger fuel regulator. that should be around 330hp
i just completede mounting an IPD Larger intercooler, IPD Intake spacer, modded Intake with 960 throttle body, a costum RIP intercooler hose setup, Turbo control valve insted of the 3 way valve, IPD CBV blue spring, IPD MSD ignition coil, Later model Exhurst manifold Japan made?.
When it came here i had a blown intake turbo at the throttle body.
Now it bogs down and dosent really want to go forward when i apply a little throttle.
when i came back to my shop and was looking to see if any of the Intercooler pipes was blown of and they wherent until i lit up the throttle it blew the upper intercooler hose off at the intercooler.
I just flused the tranny and was going drive around the block to the fluid nice an hot to check the oil level, but this happend.
Any ideas i have not really looks into it anymore because it was very late.
Im thinking the new type Turbo control valve dosent work on this model car?
gmtgmt
Post by gmtgmt »
human error, i have pulled the fuel regulator vacum line when i was flushing the transmission :wink:
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2866 times
Been thanked: 1332 times
Post by matthew1 »
Glad you found it. I didn't know where to start with all those mods.
Also -> Amazon link
