new serp tensioner help
louty
Year and Model: s70 1998
Re: new serp tensioner help
Post by louty »
precopster wrote:What happened to the old tensioner?
For my '99 V70 and for a XC70 '02 I sold I refurbished my older type by finding a seller in eBay USA that was selling a pulley only which was the same outer diameter. I recall emailing the seller for dimensions. It was a Gates brand pulley. I had to shave 1mm from each face side with an orbital sander; took 2 minutes and I had a reliable solution. Only problem is that I can't reuse the plastic cap. Using the 14mm bolt is so easy.
If you still have the old one look into it as you can always put the new one back on eBay for an indie shop that has the factory tool.
Im actually headed back to see if the new pulley ( and bearing) and bolt will fit the old tensioner. or if the old bolt will fit the new pulley and bearing set up. the mission is to replace the bearing since this one has 205k miles on it.
I did talk to my local dealer, of course they dont want to help, they are exclusive in a small town, and have an attitude.
if its a new part ( or superseeded for the older ones) and what is needed, owning 3 in ths family, Id buy a tool, they said there is not a new tool for this other than a torx and a breaker bar, whcih I think he was just repeating what I said I had tried.
and of course, why dont you bring the car in, ka-ching
louty
Post by louty »
done
mount old tensioner
hang new belt
grab 14mm wrench and twist
done
10 minutes includes mounting tensioner
not what I wanted to do, but its done and my son can have his car back
done
what a nightmare for just a stinking serp belt
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
You can always get one of these and do it later: http://www.ebay.com/itm/DAYCO-89133-Bel ... dd&vxp=mtr
Looks like it has the ridge on it so the cap can go back on, unlike the Gates one I bought.
louty
Post by louty »
yep, im either gonna do that, or make a bar and weld on a torx bit that fits the torx in the new pulley syetem
but its done for now, and being picked up in a few hours
Been thanked: 472 times
Post by cn90 »
For future reference, you can make the serp belt tool for cheap.
Find a used lawn mower blade (make sure you dull the sharp part of the blade) or a straight piece of metal (Home Depot has it).
Then go to local muffler shop and ask them to weld the T60 bit for you. Most muffler shops do this for about $5-$10.
I took this photo from another website to show you the home-made tool.
PS: I misspelled the word "Lawnmower Blade" in the pic but the picture is worth 1000 words!
louty
Post by louty »
nice cheap idea
louty wrote:nice cheap idea
It's simply beautiful when technology meets homegrown inventiveness.
