Hi Guys,
I had left my 2000 S80 garaged for 6 months (Battery disconnected) while on a overseas project. When I had left the battery was on it's way out so bought a new battery yesterday and reconnected the car. It started on the first try but noticed that the dash was blank. While checking that I also noticed that the climate control and Driver Seat were also not working. Have checked all the fuses and they are all good. Had a look at the wiring diagram and fuse 24 seems to connect to all the things not working. But the fuse is fine, can the relay be an issue?
I have read the well documented DIM issues, but can't find any mention of it also affecting the driver seat. I have also tried locking/unlocking sequence. The car is running smooth and during the test drive behaved normally.
Can anyone point out a probable cause for this. Since wife's using the other car, I need this working asap.
Cheers,
2000 S80 Dash, Driver Seat & AC not working
- cmblackburn
- Year and Model: 1998 S70 T5M
- Been thanked: 7 times
Does your car have a sunroof? IIRC the lack of a functioning sunroof+ the other symptoms can possibly be the alarm module. (I helped a friend turn around her 99 s80 t6 that was problem after problem)
1994 855 Turbo, 243k "Honey Badger"
1998 S70 T5M, 287k "The Blue Turd"
2004 S40 2.4i, 197k "Cosmo"
2005 XC90 2.5T AWD, 207k "Apollo 13"
2011 VW Jetta SportWagen TDI 6MT, 93k "Zoe"
- Year and Model: Lots
- Been thanked: 128 times
Disconnect the battery. Press the brake pedal with ignition on. Turn key to pos II and reconnect battery. How's that now?
Hi,
Tried the brake pedal sequence and it didn't work. I was reading the manual and there is a relay connected in that circuit. Can someone point out which relay and where is it located?
Regards,
Regards,
2000 Volvo s80 T2.0
2003 Ford XR6 Turbo
2001 Subaru Forester AWD
2003 Ford XR6 Turbo
- 2022 Views
Last post by EngineeringBloke
- 48 Replies
- 98192 Views
- 2195 Views
Last post by mrscullini
- 3334 Views
Last post by jimmy57
- 6683 Views
Last post by transpalette
