P80 MASTER STUCK OIL FILTER CANISTER THREAD Topic is solved
JDS60R
Been thanked: 3 times
Post by JDS60R »
You can call me if you want me to run you through it. See my number below.
Retired
JDS60R
Post by JDS60R »
You can see the top plate in the picture above my posts. If you contact the plate or the holes you will be fine. Just use the hammer to drive it to unscrew.
Retired
JDS60R
Post by JDS60R »
Just got your message and tried to call - left VM
Retired
jh_on_the_cape
Year and Model: 2006 V70 n/a FWD
Post by jh_on_the_cape »
Filter still there. I am going to order that special tool in the video. I called around and cannot find it locally. I might try one more time tomorrow.
Worst oil change ever.
Bright Red 1994 850 Wagon, nonturbo, FWD, stickshift 150k-ish miles SOLD
2006 v70 FWD nonturbo, boring silver A/T, 200k miles
Been thanked: 504 times
Post by cn90 »
Another option is to ask your local indy shops if they have the special tool that you can borrow.
Just put down a deposit, borrow it, then return it and get your deposit back.
jh_on_the_cape
No shops have the tool. I ordered it from Bogert avaition with $$ 2 day shipping.
jh_on_the_cape
I finally removed my oil filter. I ordered that special tool from Bogert Aviation. The pins bent on the first try, so I replaced them with some thicker screws. That did the trick.
see the pic of all the tools I tried on the thing.
If anyone needs to borrow this tool after reading this thread, send me a message and I will overnight it to you (on your dime).
Do not overtighten your oil filter. God kills a kitten when you do this.
keirelan
Year and Model: 2004 v70r
Post by keirelan »
I know this is an old post, but after hours of struggling with the same thing, this worked quickly for me. I took a large hose clamp, tightened it around the filter with a socket and then used a hammer to hit the socket wrench until it started turning.
Has thanked: 1611 times
Been thanked: 4075 times
Thats awesome as a trick.
I use the fluted cup type oil filter wrench and have never had one stuck, but I hand tighten only, too.
Thread renamed for search
A new plastic oil filter housing cap is still available from Volvo for about $20
1275808 is part number, for the insert filter type guys
