Does any one know how to make a Cam Locking Tool ?
zeebushwacker
Year and Model: 1999 S80 T6
Post by zeebushwacker »
I would like to make my own tool after seeing prices for a new one. Or if anyone is interested in selling one I would be interested in know your asking price.
Thanks
mlanctot
Year and Model: 1999 S80T6
Post by mlanctot »
I just borrowed one from a local shop. Gave him a check for $300 which will be refunded when I am done. Good luck.
Beachbum
Year and Model: 2001 S80 2.9
Post by Beachbum »
You don't need one for your '99 T6. Don't worry...the cam sprockets will not move when you take off the belt. At least they didn't on my '01 2.9, which is essentially the same engine as your 2.8 T6.
Just make sure you have everything lined up properly (#1 cyl at TDC, marks on plastic cover aligned with marks on cam sprockets). And BE SURE to rotate the crank 1/4 turn past TDC and then back to TDC ***BEFORE*** removing the belt. This will insure that your CVVT does not get screwed up.
You might also want to remove the crank pulley to make taking the T-belt off/putting the new one on easier. I didn't do this and it was a real PITA!
Good luck.
hanzbe420
Year and Model: 2006 s60 2.5T
Post by hanzbe420 »
as you said in your post^^^^^ I am doing my timing belt soon, do i need to do this to for a 94 turbo wagon? Also i am trying to find the thread on how to make your own cam locking tool with plumbing parts, can someone please post the link?
bskeels
Year and Model: 1997 Volvo 960
Been thanked: 3 times
Post by bskeels »
IPD's is fairly cheap and is currently on sale for $24
The Fleet
2012 Ram 2500
97 Volvo 960
98 V70 AWD (208000+)
66 Volvo 122s sedan project
98 Volvo V70 XC (151,000+) parts car
08 Volvo V50 T5
"Human history becomes more and more a race between education and catastrophe" - H. G. Wells
boosted5cyl
Post by boosted5cyl »
bskeels wrote:IPD's is fairly cheap and is currently on sale for $24
Not a lot of use on a VVT motor though. The cams themselves can move independently of the sprockets. Thais why there is a different tool that locks that cams at the rear of the block which is what the OP is asking about.
You can get away without either, but its a real pain in the ass if you plan removing the sprockets. Next time I'd get the tool.
hanzbe420
Post by hanzbe420 »
I am doing the timing belt on a 94 wagon turbo 2.3 so how do i make the tool with plumbing parts as i have read in previous post. Is there a link to this thread on how to build one? I have seen a few pictures of some homemade ones but that's its 124$ does this lock the cams at the timing belt side or the cap and router side? And its necessary to use this for the timing belt change on my car right?
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 608 times
Post by vtl »
hanzbe420 wrote:I am doing the timing belt on a 94 wagon turbo 2.3 so how do i make the tool with plumbing parts as i have read in previous post. Is there a link to this thread on how to build one? I have seen a few pictures of some homemade ones but that's its 124$ does this lock the cams at the timing belt side or the cap and router side?
Buy one, DOHC lock tools are fairly cheap, like Lisle Tools 36880 ($28 on Amazon w/ Prime) . I've got similar one from Autozone for $40-something and did the job on 2002 V70.
No, but it will make your life much easier.
Reason: Linked product to Amazon page w/ MVS code embedded.
