2001 C70 VVT Hub Cam Seal Locking Tool?
cuhfs
Year and Model: 850,XC70,XC90,S60,80
Has thanked: 17 times
Been thanked: 31 times
Post by cuhfs »
2001 C70 160K miles and I am getting ready to dig into the problem of it losing all oil (you can see in pic sprayed everywhere). Appears to be the cam seal at the VVT hub (exhaust cam). Am I correct that I wont need locking tool if I put it in time before removing T belt and mark the hub and parts that I remove and reinstall at same exact location? I Watched Roberts vid and it does show the locking tool used but he did all 4 seals both sides of cams. I don't see why I would need to lock if nothing is moved (just removed) but everything is then replaced where it was, as marked? Any thoughts? Do I need to use locking tool?
Cam Pic 11.jpg (64.72 KiB) Viewed 1058 times
Reason: Please only one question mark ? in titles
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
96 850 Wagon Manual Trans & 98 V70 (gone)
95 850 Sedan Auto Trans (gone)
04 XC70 Auto (gone)
04 C70 Convert (gone)
01 C70 Convert Manual Trans (gone)
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
You WILL need the tool anytime you break one of those VVT hubs loose.
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
For 1999+ models with VVT, yes a locking tool is needed.
The tool is about $50-$60 on ebay.
The relationship of the cam seals and the VVT sprocket is rather interesting. See link below.
Make sure you use only Volvo OEM or Corteco (which is OEM) b/c you don't want to do this job twice.
We talked about the cam seals for VVT cars in the thread below:
http://volvoforums.com/forum/volvo-xc90 ... ded-81251/
cuhfs
Post by cuhfs »
Thanks guys. Will do.
04 C70 Convert Auto
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
Has thanked: 1609 times
Been thanked: 4065 times
I've got the tool if you want to borrow and we can match timeframes
cuhfs
Post by cuhfs »
Abscate, I have the tool because I bought it when my 04 C70 skipped time due to the serp belt wrapping around the crank. Couldn't have done repair without Robert DIY's help, and the entire forum. Like many here I have gone from oil changes only, to major repairs in a short amount of time. Anyway, I very much appreciate the offer and if you can let me know when your driving by Route 80 (it be great - to buy you a beer) I am near Allamuchy, NJ Route 80 exit 19.
04 C70 Convert Auto
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
