I would like to make my own tool after seeing prices for a new one. Or if anyone is interested in selling one I would be interested in know your asking price.
Thanks
Does any one know how to make a Cam Locking Tool ?
zeebushwacker
- Year and Model: 1999 S80 T6
Beachbum
- Year and Model: 2001 S80 2.9
You don't need one for your '99 T6. Don't worry...the cam sprockets will not move when you take off the belt. At least they didn't on my '01 2.9, which is essentially the same engine as your 2.8 T6.
Just make sure you have everything lined up properly (#1 cyl at TDC, marks on plastic cover aligned with marks on cam sprockets). And BE SURE to rotate the crank 1/4 turn past TDC and then back to TDC ***BEFORE*** removing the belt. This will insure that your CVVT does not get screwed up.
You might also want to remove the crank pulley to make taking the T-belt off/putting the new one on easier. I didn't do this and it was a real PITA!
Good luck.
Good luck.
- hanzbe420
- Year and Model: 2006 s60 2.5T
as you said in your post^^^^^ I am doing my timing belt soon, do i need to do this to for a 94 turbo wagon? Also i am trying to find the thread on how to make your own cam locking tool with plumbing parts, can someone please post the link?
bskeels
- Year and Model: 1997 Volvo 960
- Been thanked: 3 times
IPD's is fairly cheap and is currently on sale for $24
The Fleet
2012 Ram 2500
97 Volvo 960
98 V70 AWD (208000+)
66 Volvo 122s sedan project
98 Volvo V70 XC (151,000+) parts car
08 Volvo V50 T5
"Human history becomes more and more a race between education and catastrophe" - H. G. Wells
2012 Ram 2500
97 Volvo 960
08 Volvo V50 T5
boosted5cyl
- Year and Model: '98 V70 T5, '99 S80
Not a lot of use on a VVT motor though. The cams themselves can move independently of the sprockets. Thais why there is a different tool that locks that cams at the rear of the block which is what the OP is asking about.bskeels wrote:IPD's is fairly cheap and is currently on sale for $24
You can get away without either, but its a real pain in the ass if you plan removing the sprockets. Next time I'd get the tool.
'04 XC90 2.5T AWD (Angus) 134K.
'99 S80 T6 (Medusa) 214k. On borrowed time LOL
'98 V70 T5 (Vivienne). RIP @ 228K. Spun rod bearings.
- hanzbe420
I am doing the timing belt on a 94 wagon turbo 2.3 so how do i make the tool with plumbing parts as i have read in previous post. Is there a link to this thread on how to build one? I have seen a few pictures of some homemade ones but that's its 124$ does this lock the cams at the timing belt side or the cap and router side? And its necessary to use this for the timing belt change on my car right?
vtl
- Year and Model: 2005 XC70
- Has thanked: 114 times
- Been thanked: 608 times
Buy one, DOHC lock tools are fairly cheap, like Lisle Tools 36880 ($28 on Amazon w/ Prime) . I've got similar one from Autozone for $40-something and did the job on 2002 V70.hanzbe420 wrote:I am doing the timing belt on a 94 wagon turbo 2.3 so how do i make the tool with plumbing parts as i have read in previous post. Is there a link to this thread on how to build one? I have seen a few pictures of some homemade ones but that's its 124$ does this lock the cams at the timing belt side or the cap and router side?
No, but it will make your life much easier.And its necessary to use this for the timing belt change on my car right?
Reason: Linked product to Amazon page w/ MVS code embedded.
