How to read your actual miles from the ECU
This topic is in the MVS Volvo Repair Database » How to Read Actual Miles from the ECU
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
blackcomb1 wrote:none the wiser this end, fly wire (where is that located?) silly question maybe but I have never done this btw.
It comes out of the bottom of the A/B boxes, There is a hole on the cover where it should be plugged in to keep it from corroding.
blackcomb1
Year and Model: 1995 Volvo 850 GLE
Post by blackcomb1 »
Ahh thank you (again), you're smart, very clued up. Though I wish a pic were posted on here so I can see exactly what I am meant to be looking at more clearly.
So from reading at the start of this thread, it's the number of blinks that tells you the mileage.
I am 100% a woman.
Post by Ozark Lee »
Ask and you shall receive.
The A/B diagnostic port boxes.
The flywire on side A.
The flywire plugged into port A-7.
You can also see the button next to the red LED.
scottyscott
Year and Model: 1995 850 Turbo
Post by scottyscott »
My odometer is broken @ 172k. Thanks for this!!!!!
'95 Volvo 850 Turbo (854T) 4 spd: 204k miles and counting
Previous: '85 740 Turbo Wagon, wrecked at 96k
Pam613
Year and Model: 1995 850 GLT
Post by Pam613 »
This may be dumb but I can't find a button. I bought a 1995 850 for my 17 yr old but the odometer does not work. The post on how to repair the odometer is clear and I can follow the photos and dialog. My problem is although I can find the ECU and I can find box A and I see several numbered holes for the fly wire. I don't see a button. Can anyone explain were the button is and what it looks like.
Pam613
Post by Pam613 »
Thanks
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Here's a video:
Pam613
Post by Pam613 »
Ok I feel a little less stupid, the button and led bulb are missing. Were the photo shows a button I have a hole with what looks like a copper diode at the bottom and were the pitcure shows a bulb I have a hole with what looks like a black screw head. Also the end of the flywire that does not fit into the sockets is loose. Is there a way to read the mileage without the button? can I go junkyard crawling and replace the piece with the missing bulb and button? and should the loose end of the wire be attached to something?
Pam613
Post by Pam613 »
Sorry guys not very good at using this forum yet, hoping posting in quick reply instead of postreply will get me a response today so I can work on my sons car. the button and led bulb are missing. Were the photo shows a button I have a hole with what looks like a copper diode at the bottom and were the pitcure shows a bulb I have a hole with what looks like a black screw head. Also the end of the flywire that does not fit into the sockets is loose. Is there a way to read the mileage without the button? can I go junkyard crawling and replace the piece with the missing bulb and button? and should the loose end of the wire be attached to something?
Foxxy
Year and Model: 850 non turbo '96
Post by Foxxy »
I have a '96 850 will this work with it too???
