Hi all -
I'm trying to troubleshoot various noises on my 2004 XC90 2.5T that I'm suspecting is coming from the engine shifting too much within its engine mounts from torque. I don't have a way to get underneath to check the bottom mounts yet, but I figured I'd check the top mount. Visually, I can't find anything wrong with it without taking it apart.
I was surprised at how much movement the engine made when rev-ing, but I don't really have a concept of what's too much, so I took the video below. Is this too much play?
Thanks!
How much play is too much on top engine mount for a 2.5T?
- Year and Model: Lots
- Been thanked: 128 times
Hell yeah. That's a lot of movement. You could possibly have two or more broken mounts there.
There is a small torque control mount going to the gearbox from the front crossmember (bottom photo)
Also a large round hydraulic mount very close to it. There are 2 of these more or less opposite each other. The other one is on the exhaust side
Also at the timing end of the engine you have a unique and rather large mount (first pic)
- uploadfromtaptalk1363473233459.jpg (51.74 KiB) Viewed 2660 times
- uploadfromtaptalk1363473270772.jpg (75.82 KiB) Viewed 2660 times
- uploadfromtaptalk1363473287181.jpg (63.96 KiB) Viewed 2660 times
joelq
- Year and Model: 2004 XC90 2.5T ~135K
Thanks, for the quick reply. Yes, I suspect I have multiple mounts that are bad, and I'm trying to figure out which ones I can do myself. From my research, the top and front ones look very doable. I'm concerned about the rear one as that sounds like a bear to replace.
You will need to have someone rev the engine while you poke around under it to see what's loose. That front hydraulic mount would be the first one to view. The nuts are 15mm from memory. If you remove the 2 bolts on the front torque mount at the crossmember and also those at the timing end as well as removing the crossbrace across the strut towers you can try to then jack the engine up at the sump by using a pine brace to spread the load.
The most fiddly one is the rear hydraulic mount to fit but it may be ok.
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
Is this the one where steering rack bolts on, near the fluid lines?precopster wrote:...
If so, would replacing it takes lowering the subframe?
- regent
- Year and Model: 2015 XC60 T5
- Has thanked: 2 times
- Been thanked: 12 times
If the hydraulic mounts have no visible leaks they would most likely be fine. It is the top engine mount, the transmission mount, and the lower front engine mount (at the belt side) that fail first usually.
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired
1987 340 DL - retired
2015 BMW 335i
- 18 Replies
- 10953 Views
Last post by erikv11
- 422 Views
Last post by manovlov
- 1072 Views
Last post by T5AUS
- 748 Views
Last post by tryingbe
- 2492 Views
Last post by Volvo Kush
