I noticed following symptoms today. I turned the ignition and the engine started as expected but the ABS light was on. I was not able to compress selector knob on the gear selector (shift stick) and could not shifted to D. I pressed on shiftlock override button and slide to D. Next I turn OFF ignition then started again and the ABS light was OFF. It was during the day.
In the evening it happened again but this time even after turning OFF and ON ignition the ABS light stayed ON. Additionally I was not able to turn low beam on , dashboard light were OFF and speedometer and odometer did not work. I was driving with high beam on the highway. Arrived home, turned OFF and ON ignition few times and finally ABS light went away and everything returned to normal. Drove around the block, everything was functioning perfectly. My ABS module was repaired by Victor at 77K (8 years ago).
Any recommendations greatly appreciated
ABS module again?
Matty Moo
- Year and Model: 850, 1996
- Been thanked: 30 times
That sounds like the ignition switch is the problem.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
Matty Moo
The next time it happens jiggle/manipulate the key and see if that takes care of it, if it does then it is the ignition switch. Everything you're describing points to it.
2000 s70 GLT
2014 Ram
- Has thanked: 1505 times
- Been thanked: 3818 times
Time for number 3 ignition switch!
I have a bad ABS module right now and it doesn't lock my shifter at all. as somebody already stated, you could have a ignition switch problem. the switch itself could be bad.
98’ S70 T5 Turbo Manual - Midnight
01' S60 T5 Turbo- Brandy
98' V70 T5 Turbo - Swifty
93’ 244 n/a - Mr.Chill
91' 940 SE Turbo - Mojo SOLD
83' 242 DL - Bluto SOLD
93' 940 Wagon - Django - SOLD
januwan
- Year and Model: 97 850 NA 205 K
- Has thanked: 7 times
- Been thanked: 3 times
Yes, it was ignition switch. I replaced it yesterday. The original failed after 90K, the second one (also Volvo) after 65K. I hope this is not indication of the Volvo's parts quality.
Thanks to all who gave me pointers.
januwan
Well I replaced my ignition switch, and all my intermittent light problems stopped - except the ABS..and now Im getting P1633 - speed sensor in ABS (to be confirmed)
Looks like I will be talking to MattyMoo soon ......
VolvoS70BASE
- Year and Model: 1999 s70
The abs units should have been made better.
Reason: Made a complete sentance and added punctuation. This is not a text message board.
