Can't get axle out of bearing hub -tried EVERYTHING!
ThatBitch_MacGuyver
Year and Model: 850 1997 wagon
Post by ThatBitch_MacGuyver »
Ok. Not a Noob to MVS I just don't post often enough so I gather I got booted off the server.
Back to business. Ok, what do you do when you can get the axle to slide out of a 1997 volvo 850 wagon(drivers side). I have tried rubber mallets, drift hammer, block o'wood and a 5 pound sledge, a gear puller.....at this point I have the car buttoned up again so I can drive it to my shop guy and have him take a whack at pulling the axle free from the knuckle and wheel bearing hub.
What can one do to remove a stuck axle? I tried tapping all around the outside of the flange to no avail. It's supposed to just slide out of the bearing but it doesn't .
Please gods of MVS I've tried everything short of using an torch to free the darn thing...without ruining the axle of course.
Thank you in advance and I will follow up later with the answer that worked.
1997 volvo 850 wagon 251,400 miles and still going strong.
ThatBitch_MacGuyver
Ps. The whole point of this is the replace the bearing and do a cv boot replace!
MrPc
Year and Model: 850R 1996
Post by MrPc »
Is the gear puller you tried three prongs or two?
When I did this a month or two ago, the axle was stuck on the driver's side as well. I tried the same things you did. The 2 prong puller I tried wouldn't stay aligned long enough to build up the needed force. A three-prong gear puller made short work of it. The one I used has a 7" spread and about a 3.5" reach. Oil the threads, it does build up a fair bit of tension.
Paul
Red Red '96 855R, 169k
ThatBitch_MacGuyver
I have the 3 prong gear puller and I cranked on it so tight I thought it was going to snap from the pressure. That didn't work either....
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
There's another way.
Loosen the clamp on the inner CVs boot and with three or four sharp pulls you can pull the inner CV apart. The casing for the inner CV stays and the shaft comes out. At this point be careful that the 3 shells stay on the shaft; nursingly cradle them with a rag as you carry the shaft to the workbench.
If one or more of the shells pops off you'll have a search and rescue for around 33 needle rollers per bearing shell. I did it this way on my '99 V70 and then cleaned & repacked the casing with a small grease gun.
When you re-insert the 3 headed shaft end use a heavy hammer to re-form the 3 metal lugs that were bent from the pulling.
I just did it this way yesterday with my '01 XC axle which wouldn't budge. With later axles they don't even have the 3 metal tangs on the inner CV casing.
Been thanked: 472 times
Post by cn90 »
Maybe someone or factory put the metal adhesive or Loctite etc.
Easy solution: use a Propane torch ($12 at hardware store) and heat AROUND the axle splines.
The idea is to use heat to expand (and melt the Loctite) the bearing splinesto allow the gear puller to do the job.
I doubt they used Loc-Tite but anything's possible. Heat won't alter the size of the snap ring which is probably a little large. Using pullers is not wise as the snap ring may be locked to a position outside the circle of the shaft. You could break the gearbox casing.
The best way is to place trans in neutral and rotate-jerk, rotate jerk. This keeps the snap ring in the middle but you must keep pressure outward all the time so the snap ring doesn't fall down again.
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 93 times
Been thanked: 146 times
Post by BEJinFbk »
The last time I had a problem with this, I built a double loop pulling cable.
The double clips nearest the loops aren't crimped, so they slide and you can choke the two loops
down for a tight fit around the axle. Set them at 180 apart for an even pull. The rubber hose in
the middle makes a nice handle.
I had planned to run the pulling end through a large weight and use it like a slide hammer,
but with the right pulling point on the axle, the clip just gave up it and the axle popped right out.
Axle Puller.jpg (36.84 KiB) Viewed 2193 times
5 bucks worth of parts at Home Depot. :wink:
xHeart
Year and Model: 2.0/3.2
Has thanked: 113 times
Been thanked: 115 times
Post by xHeart »
MVS Mavericks recommend one of the two methods: 1) take the LCA off the subframe, or 2) remove the two strut bolts at the knuckle. It will allow the knuckle to move freely.
Here is one https://www.matthewsvolvosite.com/forums/viewtopic.php?t=29716
Which method is OP using?
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
I think that cv can move in and out a little, especially if the steering wheel is turned. Every time I ever pulled the control arms off, those CV's just flapped around like they had all kinds of play.
I would loosen the nut to the end of the shaft and give it a good smack with a hammer or something to free it. Not a full baseball bat swing, just a pop. Heck, maybe my method would damage the tranny, I don't know.
