Brake lights problem
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
bukbuild
Year and Model:
Post by bukbuild »
When headlights are turned off and brake pedal depressed brake lights work fine, except the bulb warning light comes on.
When headlights are turned on bulb warning light stays on and when brake pedal is depressed, right tail light goes off and left and center work fine. Whats up with that?
93 940 Turbo Wagon
Kmaniac in California USA
Year and Model:
Post by Kmaniac in California USA »
Here is my two-cents:
Replace the brake light bulbs (you may have an internal short or electrical leakage in one).
Clean the bulb holder and light socket contacts with steel wool.
Lubricate the contacts with silicone (dielectric) grease.
These things should eliminate the problem.
Chris the "K MANIAC"
1986 740 GLE
(5) 1964 Chrysler 300-K's
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Agree with the above but also suggest you check all earth (ground) points on the rear lights.
From this I assume that is without pressing the brake pedal. If so it would appear you have a similar problem at the front.
On these cars it is not good policy to change only one of a pair of bulbs, as the difference between the old and new bulbs can upset the bulb failure system.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
