While I was under my wife's car today, I noticed the lower engine/transmission torque mount had a lot of play in it. I'm curious. What are the symptoms of this part wearing out? I only drive this car a few times a month. I've ordered a new one. What improvements should I expect?
Thanks.
Lower engine/transmission torque mount.
you may want to check the upper torque mount underneath the strut brace. If your bottom one is bad most likely your upper one is also. They keep the motor "in check" if you will underneath the hood. It should feel more solid under acceleration.
swedish tank
- Year and Model: 2004 XC70
I just replaced my lower transmission torque mount. It seems to have made the shifts more solid, but it didn't make a heck of a difference. I drive a 2004 XC70, and this is the first time that part has been replaced. The smaller bushing on the torque mount was completely disintegrated. I could turn the metal part that bolts to the bottom of the engine 360 degrees.
JRL
- Year and Model: Several
- Been thanked: 16 times
On an AWD these are good for 100K miles plus or minus
Also check the lower front mount (right side of car), they also go bad and eventually collapse
moosemanusa
- Year and Model: Different Vol's
Mine were worn out also, however I believe that was caused by missing bolts on the steering rack..
They are super easy to replace, unbolt and reverse to install.
- kcodyjr
- Year and Model: 2006 S60 2.5T AWD
- Has thanked: 17 times
- Been thanked: 23 times
Having this lower torque mount, and the upper as well, not worn out, means less engine movement when it comes on and off load, such as during shifting. That translates to quicker, crisper shifts.
5 others that came and went
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
The torque spec for two the 18mm nuts on subframe is two stage.
Is it 65Nm and 60º?
Is it 65Nm and 60º?
- 1283 Views
Last post by MadeInJapan
- 1874 Views
- 11 Replies
- 1917 Views
- 1415 Views
Last post by pgill
- 1742 Views
Last post by kosh_al
