Lower engine/transmission torque mount.
rbtsmpsn
Year and Model: s60 2002
Post by rbtsmpsn »
While I was under my wife's car today, I noticed the lower engine/transmission torque mount had a lot of play in it. I'm curious. What are the symptoms of this part wearing out? I only drive this car a few times a month. I've ordered a new one. What improvements should I expect?
Thanks.
billybobo
Year and Model: 2001 V70XC
Post by billybobo »
you may want to check the upper torque mount underneath the strut brace. If your bottom one is bad most likely your upper one is also. They keep the motor "in check" if you will underneath the hood. It should feel more solid under acceleration.
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
If upper&lower mounts are gone you'll hear and feel clanks when transmission shifts.
swedish tank
Year and Model: 2004 XC70
Post by swedish tank »
I just replaced my lower transmission torque mount. It seems to have made the shifts more solid, but it didn't make a heck of a difference. I drive a 2004 XC70, and this is the first time that part has been replaced. The smaller bushing on the torque mount was completely disintegrated. I could turn the metal part that bolts to the bottom of the engine 360 degrees.
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
On an AWD these are good for 100K miles plus or minus
Also check the lower front mount (right side of car), they also go bad and eventually collapse
moosemanusa
Year and Model: Different Vol's
Post by moosemanusa »
Mine were worn out also, however I believe that was caused by missing bolts on the steering rack..
They are super easy to replace, unbolt and reverse to install.
kcodyjr
Year and Model: 2006 S60 2.5T AWD
Has thanked: 17 times
Been thanked: 23 times
Post by kcodyjr »
Having this lower torque mount, and the upper as well, not worn out, means less engine movement when it comes on and off load, such as during shifting. That translates to quicker, crisper shifts.
5 others that came and went
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
The torque spec for two the 18mm nuts on subframe is two stage.
Is it 65Nm and 60º?
