Hi all,
The steering had been getting a stiff at times. Not always, sometimes.
My engineer brother in law drained the power steering oil and replaced it yesterday and now it's even worse and accompanied by godawful whining / whirring sounds that raise in pitch and volume as we accelerate. The steering wheel is also vibrating and even shaking for the very first time too. It also sound terrible and vibrates as we turn but even makes a lower noise at a standstill.
Any advice for us? We'll arrange a service but the soonest will be in 4 days. It really was drivable until yesterday now we're worried that driving it is causing damage and is even unsafe!
Thanks,
John
2008 v70 steering worse and now whining after oil change
John I white
- Year and Model: V70
John I white
John I white
Hi again,
It's Eurol brand.
Green in colour
Power steering fluid C.
Fully synthetic.
DIN 51524 PART 3
Reads, "meets requirements of VOLVO STD 1273.36"
The motor factors reccommended it for this year of v70.
It's Eurol brand.
Green in colour
Fully synthetic.
DIN 51524 PART 3
John I white
Hi. My brother in law suggested that there might be a bit of air in it. But he checked all the hoses and they seemed fine.
Thanks again
Thanks again
swimNdrive
- Year and Model: 2004 xc70
He may have already tried it, in case not, try to bleed the system to get all the air out. Then you may find you need to add more fluid to replace the air in the system.
John I white
Hi there,
Yes he pumped - rather than drained - via a syphon tube and an attached atomiser pump (!) a lot of brown fluid out and brushed out some grunge then filled it up with new stuff.
Should the fluid actually be drained out the bottom somehow instead? Will that help to remove air bubbles/locks?
vtl
- Year and Model: 2005 XC70
- Has thanked: 114 times
- Been thanked: 606 times
Your engineer probably forgot that two different fluids have different density, kinematic viscosity, etc. He did it totally wrong, no wonder that car complains as it is faced to cavitation effects in steering pump.
The whole system needs to be flushed, not just oil tank.
John I white
Do you mean there's still some old fluid further into the system with new stuff sat on top of it?
