1998 v70 GLT fuel pump part number?
stephansvolvo
- Year and Model: V70 GLT 1998
- Has thanked: 21 times
- Been thanked: 3 times
Does anyone know the part number for the fuel pump and the best place to purchase it?
Stephan
84 240GL my first(sold)
88 240GL(timing belt killed it)
98 S70 GLT
73 IH Scout ii
98 S70 GLT
73 IH Scout ii
- Has thanked: 311 times
- Been thanked: 817 times
The best way to do a fuel pump job on these cars is to read the DIYs then buy a Bosch 69693 fuel pump insert. It is usually cheapest from Amazon (use the Amazon link at the top of the page to give MVS a small kickback when you buy there), about $95 the last time I checked.
There are cheaper fuel pump alternatives, but I wouldn't go with an insert other than Bosch or Walbro and the Walbros are reportedly a bit noisy.
- Been thanked: 504 times
1+ to Bosch Fuel Pump, about $90-$100, and it will last you another 150K.
While there, make sure you go over these DIYs:
EVAP Hose:
https://www.matthewsvolvosite.com/forums ... hp?t=60269
Rubber Seal:
https://www.matthewsvolvosite.com/forums ... hp?t=60329
Gasket at Filler-Tank connection:
https://www.matthewsvolvosite.com/forums ... hp?t=60291
EVAP Hose:
Rubber Seal:
stephansvolvo
erikv11 wrote:The best way to do a fuel pump job on these cars is to read the DIYs then buy a Bosch 69693 fuel pump insert. It is usually cheapest from Amazon (use the Amazon link at the top of the page to give MVS a small kickback when you buy there), about $95 the last time I checked.
All of these parts look like the one I purchased and it has this hard plastic case around it. It wouldn't come out. It cost me 220.00. The pump insert I pulled out didn't have any casing around it. What to do you guys think? If I figure out to post a picture I will.
Stephan
98 S70 GLT
73 IH Scout ii
98 S70 GLT
73 IH Scout ii
If you bought a preassembled pump in the white casing, then you are good to go. Just install it.
Does it look like this?
stephansvolvo
IMG_0100.JPGcn90 wrote:stephan,
To save time/clarify, post a few photos so we can help you.
It's the one inthe right I pulled out
Stephan
98 S70 GLT
73 IH Scout ii
98 S70 GLT
73 IH Scout ii
Read the "reviews" in the links below and you will know what to do. Basically minor modifications and that is all:
https://www.amazon.com/Bosch-69693-Origi ... B000BZJJEW
http://www.fcpeuro.com/products/volvo-f ... 70-s70-v70
Below is a DIY for Walbro but the idea is the same for Bosch:
http://volvospeed.com/vs_forum/topic/30 ... t-how-too/
http://volvoforums.com/forum/volvo-850- ... 759/page2/
PS: Please post a few photos of your DIY for future reference.
stephansvolvo
I took off the black casing and it fit like a glove and it seems to work. Outside temp when I changed it was around 50. It was straight forward.cn90 wrote:Read the "reviews" in the links below and you will know what to do. Basically minor modifications and that is all:
Thanks for all the help guys!~
Stephan
98 S70 GLT
73 IH Scout ii
98 S70 GLT
73 IH Scout ii
