Drain holes on 850
Drain holes on 850
I just unclogged my trunk lid drain holes on my 850 which should prevent my spare tire area from filling with water. Where are the other drain holes on the 850?
MadeInJapan
- Has thanked: 17 times
- Been thanked: 35 times
Front cowl (under the windshield, visible under the hood) and the four corners of the sun roof if you have one.
how did you unclog them, I have a drain hole on the right side of my truck that fills up with water, i used a coat hanger that I bent so it wouldn't tear the rubber, but it seems that i can not get that far down to completely unclog it.
any suggestions
any suggestions
also two in the trunk on the trunk rear deck lid (one on both side) between the wheel and rear winshield
THE FLEET!:
93 854 GLT 20v non-turbo 435,000 KM +
94 854 20v non-turbo 215,000 KM ..new engine
87 745 B230 non-turbo 250,000 KM (newest edition Jan '07)
86 244 GL B230 non-turbo 460,000+ KM
If you have access to a compressor, use that to blow thru the drain holes. look for where the "out" is for the drain holes and make sure you get the junk out so they don't plug again.
Own a 94 855 Sportwagon, Restored 67 Camaro RS, 60 Chevy 4x4 Mini Monster Truck
MadeInJapan
I used a plumbers snake...worked fine.
- akitawagon
- Year and Model: 1997 855R
Sorry, my camera died. If I can snag my wife's I'll try to take a shot.
If you open up your truck lid, look at the far top left and right corner areas that are normally covered when the trunk is closed. There should be a small 1/4" hole at each corner.
When you take out your trunk liner on the left and right sides, you can trace the plastic hose on each side that leads from the drain hole down to the trunk well drain and out of your car.
1998 V70 T5 223K
1997 855R 215K
1997 855R 124K KIA... distracted driver on phone
1997 855 T5 141K KIA... water pump
1996 850 GLT 160K
1995 855 GTA 325K KIA... distracted driver on phone
1993 850 GLTS 201K KIA... t-boned
1997 855R 215K
1996 850 GLT 160K
- Has thanked: 2652 times
- Been thanked: 1243 times
While camping two days ago I found a very good tool for cleaning the trunk drains: 36-Inch Heavy Duty Cable Ties. I haven't tried it on the other drains.
That's a $20 50-pack. Maybe not the best cost/benefit ratio for the occasional unclogging session, but if you need these for other things, they're outstanding, and very very strong. Monsters.
Far better than coat hangers, and each side took perhaps 10 seconds. They're long enough to get all the way through the drain tubes. I watched the water disappear down the drains after a few pokes.
(The water was pooling during a rainy morning, and I had to find something quick. I had a few of these in the car. "Necessity is the mother of invention"
