Hi,
Like to know if anyone would know how to remove rounded bolt head (T40) on cam position sensor, the top engine mount bracket is in the way ?
1994 Volvo Removing Rounded bolt from Cam Position Sensor
- Year and Model: Many Volvos
- Been thanked: 75 times
Remove the bracket.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
They are pretty soft so I removed my with a drill bit by hand.
Hey, Thanks for the reply, yeah they are soft, I know, I had to remove bolts from Thermostat Housing, lol
You used a drill bit by hand !! you held a 5/8 drill bit in your hand , and turned it??
rspi wrote:They are pretty soft so I removed my with a drill bit by hand.
- rspi
Contact rspi..
I was about 150 miles from home in a parking lot when it stripped and would not come out so I tapped it in a socket and turned it with a screw driver. Took about 25 minuted but it was grounded out enough to start turning.
