99 s70 base P0172 persistent code, stalling
nonturbo
Year and Model: S70 / 1999
Post by nonturbo »
I have been getting returning p0172 code, haven't replaced air/fuel sensor yet. checked for vac leaks , none, replaced "j" hose rear . Persistent stalling at any speed, like it's leaning out too much, starving for gas, no vapor smell from tail pipe ( it's normal or lean), not like sulfur or burning eyes. Thanks in advance for your help !
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Have you tested the fuel pump relay?
Has thanked: 311 times
Been thanked: 817 times
p1072 is almost always vacuum leaks, when it isn't vacuum it is usually the front O2 sensor. Occasionally it is the MAF. So if you are totally sure about the vac lines, including the PCV system (did you check the elbow on the passenger side of the intake manifold? the hoses at the throttle body?), and especially if you know the front O2 sensor is aging, it's probably time to get a new one.
