1999 V70 overheating
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Re: 1999 V70 overheating
Hook up a OBD-2 tool to it and read the live data when it starts to raise to verify the temperature. There is a chance that the water pump is bad. I believe the system is pretty simple. Water pump, thermostat, coolant, radiator and circulation. To much heat and pressure for the system to clog up.
- MoVolvos
- Has thanked: 310 times
- Been thanked: 524 times
Do you have an air leak from the Reservoir Cap?roberius wrote:Blown Head Gasket.
Cha-ching!
Thanks for the inout!
Do you see Fluid return from the small top Hose into the Expansion Tank?
Did you check to see if the car will overheat while idling?
If I remember correctly one member in a recent Post said this worked for a year or more in his car. Don't remember if he found his current problem related to the cooling system
Fixing Tough Head Gasket Leaks
How to prevent your car's head gasket from blowing
- rspi
Contact rspi..
What caused the blown head gasket?
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
Thanks for coming back to close the thread! Too often people never do that.
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 111 times
Funny -- I just saw this. I would have put money on a faulty engine coolant temperature sensor. In my experience, ECT, thermostat and leaky expansion tank cap are reasonable starting points for overheating issues.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
Hi
my adorable c70 convertible is overheating, and $1,800. later still overheating. Volvo dealer in Albuquerque states rebuilt or new engine needed. Help?
has $135,000. miles I drive 40 miles twice a day to clinic and it is hot out here in New Mexico plus higher altitude .Please , any advice?
mecheng
- Has thanked: 15 times
Besides the obvious leaks, you may have a bad water pump or faulty thermostat (although most fail open).L Kirby wrote: ↑18 Aug 2017, 06:24 Hi
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
