New proud owner of an 850r
Well I got the OBD-II reader and the fault code is "P0172 Bank 1 system too rich". I did a quick search online and apparently it could be a number of things causing the engine to run to rich. Like an O2 sensor, or a faulty ignition system, or a bad MAF. This doesn't seem like anything too horrible though. Anybody run into this before with suggestions on where to look first? Thanks for all the help so far. I'm really liking the community around these things
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Start searching for a vacuum/air leak. Start with the elbow that connects to the intake manifold behind the power steering pump.
Ignore the jury-rig (couldn't reach the flipping hose), but this is the location. That elbow has probably fallen off/deteriorated. If so, re-connect it and evaluate the health of the PCV system.
'98 S70 T5
2016 Chevy Cruze Premier
jblackburn
Not that I can find - sorry. Look in the little cranny behind the alternator - behind the thermostat/upper coolant hose. There's about a 3" space in there, and a vacuum hose should connect to a little port on the intake.marklar wrote:I'm new, do you have a pic of that zoomed out a bit?
'98 S70 T5
I think I found the line you were telling me about, mine doesn't have a clamp and its going the opposite direction. I also found a corroded hose that goes to the fuel injectors so that might be it
jblackburn
That looks like it - looks ok from here.
Yes, the fuel pressure damper hose does look like it's falling apart. Search around the engine bay - namely the vacuum tree and turbocharger area - for any falling-apart elbows like that and replace whatever is necessary. You can just use straight vacuum hose if you can't find elbows.
The interior/exterior look to be in very good shape. I love red Volvos.
'98 S70 T5
rmmagow
- Year and Model: V70 1998
- Been thanked: 2 times
Looks like it might have been owned by an enthusiast. That can be a good thing. Keep an eye out for modifications though. That's a nice looking old Volvo you've got there. You are on the right group too for resolving any issues that come up. They'll help you keep it running for the next 20 years.
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
That is the same year and color as mine! Great looking R!
Mine was a one owner, low mileage car and maintained at the local Volvo dealer very well but that doesn't mean there wont be minor issues. I have had a few minor issues but I don't expect too much in the "major service" department due to its great maintenance records.
1997 854R
IPD Intake
Ported/Polished Intake Manifold w/3" Throttle Body
Old IPD Strut Brace
ARD Stage 2 Tune
IPD/TME Exhaust
IPD/Koni Suspension
Manual Swap
IPD Intake
Old IPD Strut Brace
ARD Stage 2 Tune
IPD/TME Exhaust
IPD/Koni Suspension
Manual Swap
- 1554 Views
Last post by jwalker275
- 593 Views
Last post by chestermo
- 2402 Views
Last post by foggydogg
- 20 Replies
- 5098 Views
Last post by 850 LPT
- 756 Views
