hello,
i recently did an oil change using 5/30 synthetic (what ive always used) and now i have a ticking lifter. i did use a fram filter this time (only thing available) but after reading on here I'm going to swap it out tomorrow.
the thing that concerns me is the lifter noise does not go away after driving it for a while. I'm hoping the new filter will fix it as it did not make noise before the oil change.
any suggestions would be appreciated. this is in a v70 t-5
Thanks!
changed oil, now have lifter ticking all the time
SpeedyPete
- Year and Model: S70-T5, 1998
Hi: How many miles are on the car?
- Year and Model: Many Volvos
- Been thanked: 75 times
Get rid of the orange can of death, replace it with a Mahle or a MANN, and the lifter noise should go away. Particularly the noise at start up. Lifter noise at higher RPMs, after startup, is usually a sign that the sump O rings are bad but they typically don't go bad all at once as you describe the symptoms
SpeedyPete
Well, Please let us know if changing the oil filter helps. At 145k the sump seals can come into play. Are you using any oil between changes? And how often do you change your oil? Regards, SpeedyPete
i will let everyone know if the filter makes a difference. the car isn't burning any oil but i oil cooler lines have a leak so i do end up adding in between oil changes. those are next on my list to replace. i change the oil with full synthetic about every 5,000 miles.
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 73 times
My money's on the filter! Stick with Mann/Mahle.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
- Been thanked: 467 times
1+,
Get rid of Fram ASAP!!!
Choices for 1993-1998 models:
Mann W917 (Bosch 72138 is basically Mann).
Bosch 3321 (Autozone has this)
Mahle OC-204 (Napa auto parts carries this)
rmmagow
- Year and Model: V70 1998
- Been thanked: 2 times
Buy a case from FCP. I bought the Mann W917's no ticking, 215K miles change about every 7500 with Walmart synthetic. Car is driven fairly hard, 100 miles a day and 70+
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
well, i replaced the filter, still ticking. I'm going to change to a heavier weight oil this afternoon to at least band-aid fix the issue (hopefully) for now. then replace my sump seals later this summer... not looking forward to that one!
This happened once before also where it ticked for a week, then went away for the entire winter.
- 3476 Views
Last post by Klausc
- 1516 Views
Last post by RickHaleParker
