Any coolant loss is not normal. Have you considered an internal leak (HG maybe)?cn90 wrote:I lose about 1 cup of coolant every 3K miles. Absolutely no external leak.
- Radiator is new.
- All Hoses are new (large hoses, small turbo coolant hoses).
- WP is new (done with TB job).
- Reservoir/cap are 1 yr old.
So, I have come to accept that 1 cup coolant loss/3K miles is "normal".
The last place I was looking was the Heater Core.
I opened up the side carpets, took a peek, nice and dry with absolutely no coolant residue.
So not leaking from Heater Core.
With all the posts in forum about leaking Heater Core DIY, this leads me to the basic question:
Is it possible for Heater Core to last this long (160K) with no leaks?
Do you have a cooling system pressure tester? Best thing to do is pressure test cold engine overnite; then find out where the coolant went the next AM.. may want to pull the plugs before cranking it next morning..
