2000 volvo s70 aacv torx star size?
fars70
Year and Model: S70 2000
Post by fars70 »
Hello,
I am trying to replace the air assisted control valve and/or clean it but the torx is not standard. It is between a t15 and t20,but I can't find anything in between at my local hardware store. Thanks. There looks top be two screws to remove it. And how do do you clean it, just with air throttle cleaner and a toothbrush?
burnout8488
Year and Model: 1999 S70 AWD
Post by burnout8488 »
Can you shed some light on what this AACV is? That's not a common abbreviation or part name around here. Idle air control valve perhaps?
Perhaps I'm drawing a blank. :)
'13 BMW X1 35i M-Sport
'99 S70 AWD/FWD - 198K - FOR SALE!
Has thanked: 1500 times
Been thanked: 3812 times
burnout8488 wrote:Can you shed some light on what this AACV is? That's not a common abbreviation or part name around here. Idle air control valve perhaps?
Me too. No IAC valve on a 2000 with ME7 though.
fars70
Post by fars70 »
If you scroll down you can see some pictures from another forum, it's a denso part. http://www.volvoforums.org.uk/showthread.php?t=156664
deepsouth
Year and Model: 2001 Volvo XC70
Been thanked: 8 times
Post by deepsouth »
You're talking about the Idle Control Valve. Photo from FCP below. Other than standard cleaning I'm not certain how it comes apart.
Eric
2000 S70 GLT SE, 175,000
2001 XC70, 129,000
fars70
Post by fars70 »
deepsouth wrote:You're talking about the Idle Control Valve. Photo from FCP below. Other than standard cleaning I'm not certain how it comes apart.
Eric
Oh. I meant unscrewing it from the hose looks like it requires a 5 lobed torx, T17? But I can't find anything with a T17 sized head.
In that link the poster refers to security torx...5 lobed torx that require you to purchase yet another special tool.
The poster also simply ground a slot into the head to take a standard screwdriver, btw. 10 minutes work with a Dremel.
fars70
Post by fars70 »
Thanks. But then I would have to buy a Dremel. I'll see if I can find someone who has one. Otherwise where could you buy such a special tool?
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
5 sided security torx are usually sold by Snap-On dealers. That's where I bought my Toledo set from for around $20. Call one in your area and they will let you know if they stock one.
You need a Dremel anyway....seriously, a one use tool like this can be bought at the discount places like Harbor Freight
