96 850 Turbo - Identify part & routing hoses
neworleans
Year and Model: 2007 S60R
Post by neworleans »
Hello All,
I am working on another project 850 turbo.
Can you all please help me identify the part #4 please? This thing is not attached to anything, just hanging in there and 3 small diameter hoses are connected as I numbered them 1, 2 and 3. I replaced number 1, number 2 is not connected to anything, is this supposed to be like that? And finally, number 3 goes all the way under the pcv nipple, what is the best way to reach that hose? Under the car?
My other question is, the hose oem part # is 976735 but can't find it to purchase, I need to buy 3-4ft to replace these two hoses, the one I replaced for number 1 was given to me from a friend and it was just enough to replace #1.
Thank you in advance...
kahl
Year and Model: 2000V70XC
Been thanked: 10 times
Post by kahl »
that looks like the turbo control valve. it should have an electrical connection the 3 hoses going to the turbo charger.
neworleans
Thanks for your input, yes it has an electrical connection but what I meant was that it is loose not bolted to anything.
kahl
Post by kahl »
It has a clip, goes or inserted around the air cleaner box.
Ben850
Been thanked: 7 times
Post by Ben850 »
kahl wrote:that looks like the turbo control valve. it should have an electrical connection the 3 hoses going to the turbo charger.
Yes. I see the color coded dot next to a fitting.
color coding Dots will be on that module next to each fitting if you are fortunate.
Some vacuum lines are altered for emission designs.
Gratuitous photo.
Gratuitous photo.
All my lines are blue now so I have to pay attention when I unhook things.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
