99 c70 No reverse manual transmission
I have a 99 c70 with a manual transmission. I lost reverse but I can still shift into all other gears. What could be the problem I am facing? I need to fix this so for this is my only car.
- Has thanked: 1497 times
- Been thanked: 3810 times
It could be a linkage problem (you will need an expert for that to chime in) but more likely an internal transmission problem. Ugh. A used transmission is probably the way to go.
Don't forget to price out circular driveway vs used trans if it isn't the linkage.
I drove an old Beetle for 3 years without reverse once
rmmagow
- Year and Model: V70 1998
- Been thanked: 2 times
The link above is your best bet for checking the linkage. You'll need a helper to move the shifter while you look around. That link seems to cover about all you can do linkage-wise.
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
- Has thanked: 2650 times
- Been thanked: 1240 times
Try Volvo Salvage and Southern Vo Vo, they're sponsors -- top right ads on all pages. If you have AdBlock on you should disable it for MVS to see the ads.
