99 c70 No reverse manual transmission
HulkC70
Year and Model: C70 99/00
Post by HulkC70 »
I have a 99 c70 with a manual transmission. I lost reverse but I can still shift into all other gears. What could be the problem I am facing? I need to fix this so for this is my only car.
Has thanked: 1502 times
Been thanked: 3817 times
It could be a linkage problem (you will need an expert for that to chime in) but more likely an internal transmission problem. Ugh. A used transmission is probably the way to go.
Been thanked: 468 times
Post by cn90 »
Don't forget to price out circular driveway vs used trans if it isn't the linkage.
I drove an old Beetle for 3 years without reverse once
HulkC70
Post by HulkC70 »
So how do I check the linkage? I can't afford to take it somewhere so how difficult is it to do on my own?
rmmagow
Year and Model: V70 1998
Post by rmmagow »
The link above is your best bet for checking the linkage. You'll need a helper to move the shifter while you look around. That link seems to cover about all you can do linkage-wise.
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
HulkC70
Post by HulkC70 »
Ok so it's definitely the shift cable. It's shredded. Volvo wants 170 for a new one and I can't afford that. Does anyone know where I can get one for cheaper. There is no yards around me with one?
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2652 times
Been thanked: 1242 times
Post by matthew1 »
Try Volvo Salvage and Southern Vo Vo, they're sponsors -- top right ads on all pages. If you have AdBlock on you should disable it for MVS to see the ads.
Also -> Amazon link
HulkC70
Post by HulkC70 »
Thanks
Post by cn90 »
On the other hand, thevpstore dot com (Volvo dealer in KC) sells the cable for $150.
