Front strut mount rebuild.
road1will
Year and Model: 2004 XC90 2.5T
Re: Front strut mount rebuild.
Post by road1will »
I did this job today and it was much easier than expected. took me about 45 minutes per side to do. I bought the special tool from IPD and it really isn't the right tool - It does have a tool to grab the star shaped nut, but the counterhold part of the tool is not correct, at least not for the XC90. I ended up using a punch and a hammer to knock the nut loose.
Been thanked: 474 times
Post by cn90 »
Old thread but I want to ask the gurus a question.
I did the front suspension overhaul on my 1998 S70 (a 3500-lb car) a few years ago:
https://www.matthewsvolvosite.com/forums ... =1&t=28455
The question is for my newly acquired 2005 XC90 2.5T (a 4500-lb car):
- The SPRING COMPRESSOR is the type from Autozone, can I use these standard spring compressors (that I used on my 1998 S70) to compress the springs of an XC90?
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Usually an AWD spring is quite a bit longer than a road car and generates a little more force when compressed. My XC70s springs were easily compressed with my el cheapo compressor using an air ratchet however I just don't like using them at all. An XC90's may be longer and of greater tension than an XC70, though.
The larger and more robustly made the lower the chance of breakage and potential injury, however even the best ones could slip.
There are solutions that are wall mounted and much safer. If you're a subscriber to BriansMobile on YouTube he dedicated a video to his new wall mounted unit.
