850 PCV System vacuum hose connection
Noerty
Year and Model: 850 2.5 20V 1996
Post by Noerty »
Good day,
I just had to replace the head gasket on my 850.
It is driving in South Africa and unfortunately I cannot find a good routing diagram of my type of PCV system.
On my oil trap I have two large hoses one going to the tappet cover. One to the flange with the sieve on the intake hose.
BUT there is also a vacuum hose connected on the pipe towards the intake hose. It's connection is close to the oil trap. Where is the other end supposed to connect to? I will try to find a diagram and post it ASAP
Thank you guys for your help I couldn't find information anywhere so far.
Noerty
Post by Noerty »
This is the picture. The hose looks like number 9.
http://www.volvopartswebstore.com/image ... -75990.jpg
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
What instructions are you using to complete the job? Surely you have some guidance. Also, what year is the car?
rspi
Post by rspi »
Has thanked: 292 times
Been thanked: 765 times
That hose configuration is not one that I have ever seen before here in North America. But logic would suggest that the short piece of hose on #9 goes to the nipple on the passenger side of the intake manifold, is that nipple open?
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
rspi
Post by rspi »
'92 and early '93 car stuff. Yuk!
Noerty
Post by Noerty »
I have a Haynes manual here. The car is running in South Africa that's maybe why the routing is different different emission specs. I could kick my ass not spending more attention to this. I didn't see a nipple there, I will check again tho. It's one of the cars with the variable intake manifold length by the way.
It is officially a 95. Also has OBD2 so I guess the routing differes because of emission legislation. And my pcv is from an older version.
Noerty
Post by Noerty »
Just found the nipple on the intake. I didn't see it, assembled the car on Friday night stupid me. Thanks guys !
You are welcome!
Does the hose in question seem to fit naturally on that nipple? I am curious because the end of the hose does not have a right angle bend, I would have expected that.
'06 S60 R, 197k
